Setup
- Running on Intel NUC PC
- Installed Home Assistant OS directly via Ubuntu
- OS Version 16.2
- Core Version 2025.10.3
- Server is connected via Ethernet to a router that I am using as a network extender. This router is connected via eithernet to my Verizon FiOS router
Description
Hi everyone, for the past two-three weeks, I’ve been running into a recurring issue with my Home Assistant server. It seems like randomly (sometimes multiple times a day, sometimes once every day or two) the Home Assistant becomes unreachable locally.
When I try to connect with IPADDR:8123 from my other devices, sometimes it shows an error message saying that it the page can’t be reached.
When this spontaneous crash happens, I can hear my NUC running but when I try to connect it to my monitor via HDMI, nothing appears on the screen.
It had been working fine for the past 2 months. It’s only recently that things started behaving strangely. I have even tried a clean install and I am still seeing the issue happening sometimes.
I am trying to figure out the cause of the issue. It’s been bugging me for the past 2 weeks. I am aware that I will need to provide more info (logs and such) and that it will take a while to diagnose the issue and I am hoping for some guidance from you all on how to figure this out. Hopefully it’ll be a good learning experience. But since this issue isn’t replicable on demand, this will probably be an ongoing thread where I try to provide more info on each subsequent crash.
Logs
Here is a snippet of Host logs from before I noticed it crashed. I rebooted it by turning the power off and on at approximately 13:41
2025-10-21 13:19:00.301 homeassistant systemd[1]: Started libcontainer container 533ca05aa1bd2bbce5504a55c8b351e06eac0c932c98d5994cd2627afc4f8735.
2025-10-21 13:19:04.359 homeassistant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
2025-10-21 13:19:07.013 homeassistant systemd[1]: var-lib-docker-overlay2-d4efed4f064e3434e26b647e52d10f5256ed15678144b9169711da0f7313c59e\x2dinit-merged.mount: Deactivated successfully.
2025-10-21 13:19:07.014 homeassistant systemd[1]: mnt-data-docker-overlay2-d4efed4f064e3434e26b647e52d10f5256ed15678144b9169711da0f7313c59e\x2dinit-merged.mount: Deactivated successfully.
2025-10-21 13:19:07.081 homeassistant systemd[1]: Started libcontainer container dda9c8507b764ebcb74ae32ab79f36bdb601c0eae0c82f9039b9d4615dcb3831.
2025-10-21 13:19:10.419 homeassistant systemd[1]: var-lib-docker-overlay2-88d757d6a793636cb793739819886cc81af9302645315ca8b0d7f804db366392\x2dinit-merged.mount: Deactivated successfully.
2025-10-21 13:19:10.419 homeassistant systemd[1]: mnt-data-docker-overlay2-88d757d6a793636cb793739819886cc81af9302645315ca8b0d7f804db366392\x2dinit-merged.mount: Deactivated successfully.
2025-10-21 13:19:10.504 homeassistant systemd[1]: Started libcontainer container e35e68ddd6baec464f5fa8d7483030acf96fd18f55c1304b3da92d60e0be622a.
2025-10-21 13:19:10.530 homeassistant kernel: hassio: port 7(vethc0f8c63) entered blocking state
2025-10-21 13:19:10.530 homeassistant kernel: hassio: port 7(vethc0f8c63) entered disabled state
2025-10-21 13:19:10.530 homeassistant kernel: vethc0f8c63: entered allmulticast mode
2025-10-21 13:19:10.530 homeassistant kernel: vethc0f8c63: entered promiscuous mode
2025-10-21 13:19:10.531 homeassistant NetworkManager[455]: <info> [1761052750.5311] manager: (vethc0f8c63): new Veth device (/org/freedesktop/NetworkManager/Devices/14)
2025-10-21 13:19:10.560 homeassistant kernel: eth0: renamed from vethb8df9c4
2025-10-21 13:19:10.561 homeassistant NetworkManager[455]: <info> [1761052750.5613] device (vethc0f8c63): carrier: link connected
2025-10-21 13:19:10.561 homeassistant dockerd[564]: time="2025-10-21T09:19:10.561336309-04:00" level=info msg="Skipping check for route to send NA, EMSGSIZE" eid=5de98f09a8420e9fee0aa7bbc6c08a7b3b2abe355c97ad6bbbbf0fe57ce2c88b ep=addon_45df7312_zigbee2mqtt net=hassio nid=fdecf0bb137b14e0ec185a4c82d6fcd4cdaed66ce53b8295eb982811cb264b69
2025-10-21 13:19:10.561 homeassistant kernel: hassio: port 7(vethc0f8c63) entered blocking state
2025-10-21 13:19:10.561 homeassistant kernel: hassio: port 7(vethc0f8c63) entered forwarding state
2025-10-21 13:19:11.219 homeassistant kernel: warning: `matter-server' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
2025-10-21 13:19:45.676 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2025-10-21 13:19:45.677 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
2025-10-21 13:41:55.983 homeassistant kernel: Linux version 6.12.43-haos (builder@75f99402e96f) (x86_64-buildroot-linux-gnu-gcc.br_real (Buildroot -g49cc2691) 13.4.0, GNU ld (GNU Binutils) 2.43.1) #1 SMP PREEMPT_DYNAMIC Mon Sep 8 17:12:31 UTC 2025
2025-10-21 13:41:55.983 homeassistant kernel: Command line: BOOT_IMAGE=(hd0,gpt2)/bzImage root=PARTUUID=8d3d53e3-6d49-4c38-8349-aff6859e82fd rootwait zram.enabled=1 zram.num_devices=3 systemd.machine_id=fe70375c92bc401ab300f7e96acb7b61 fsck.repair=yes console=tty0 rauc.slot=A
2025-10-21 13:41:55.983 homeassistant kernel: BIOS-provided physical RAM map:
Logs from Core
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2025-10-21 09:00:36.824 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-10-21 09:00:36.843 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=31 from 2025-10-21 12:53:37.114280)
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
2025-10-21 09:09:15.198 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-10-21 09:09:15.216 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=32 from 2025-10-21 13:00:36.816571)
2025-10-21 09:19:03.544 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-10-21 09:19:03.581 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=33 from 2025-10-21 13:09:15.190151)
2025-10-21 09:42:22.377 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
Supervisor logs. Here I noticed that there was a DNS server error. Maybe this could be it?
2025-10-21 09:19:10.371 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-10-21 09:19:10.371 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 1 add-ons
2025-10-21 09:19:10.391 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
2025-10-21 09:19:10.617 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/zigbee2mqtt/zigbee2mqtt-amd64 with version 2.6.2-1
2025-10-21 09:19:10.816 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from 45df7312_zigbee2mqtt
2025-10-21 09:19:13.798 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-user'
2025-10-21 09:19:14.060 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-user'
2025-10-21 09:19:15.634 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-10-21 09:19:15.635 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-10-21 09:19:15.636 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-10-21 09:19:15.636 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-10-21 09:19:15.639 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-10-21 09:19:15.639 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-10-21 09:19:15.639 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-10-21 09:19:15.639 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-10-21 09:19:15.639 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-10-21 09:19:15.640 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-10-21 09:19:15.644 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-10-21 09:19:15.648 INFO (MainThread) [__main__] Running Supervisor
2025-10-21 09:19:15.648 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-10-21 09:19:15.663 INFO (MainThread) [supervisor.host.services] Updating service information
2025-10-21 09:19:15.667 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-10-21 09:19:15.669 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-10-21 09:19:15.683 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-10-21 09:19:15.684 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-10-21 09:19:15.684 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-10-21 09:19:15.684 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disk_lifetime/system
2025-10-21 09:19:15.686 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-10-21 09:19:15.686 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-10-21 09:19:15.687 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-10-21 09:19:15.805 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-10-21 09:19:15.814 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-10-21 09:19:15.880 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-10-21 09:19:15.880 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-10-21 09:19:15.881 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
Next Steps
I just found out about the Home Assistant Observer so during the next crash, I will be trying to access that link to see what I can figure out from there.
What else should I take note of when I notice the next crash? And what can I do to further investigate right now?
