Home Assistant behind Synology reverse proxy
Hello all!
I have my home assistant running on my local network behind synology reverse proxy.
https://ha.mydomain.com (port 443) --> Synology NGINX reverse proxy --> Raspberry-pi (http://localip:8123)
This is working fine. However I cannot access others services running on my Raspberry-pi: For example IDE ( port 8321)
Is there any way to make it accesible on the same subdomain? Herhaps like this: https://ha.mydomain.com/IDE
Found a workaround.
I created a second subdomain and created a reverse proxy to forward me to the other service.
https://ha2.mydomain.com (port 443) --> Synology NGINX reverse proxy --> Raspberry-pi (http://localip:8321)
Then I included this in my configuration.yaml file:
panel_iframe:
  ide:
    title: IDE
    icon: mdi:code-braces
    url: https://ha2.mydomain.com
Now I can acces the service on https://ha.mydomain.com/ide
Hi, I also have the same problem, but don’t want to create 10 new subdomains now.
Does anyone know a way to use the possibilities of NGINX at Synology? It is possible to refer to another IP:PORT via proxy_pass via location /folder/ .
