Home Assistant Bug?
by the 3 last release in installed (im currently under 0.85.1) Hass.io stop working correctly after 2/3 days…
and show sqlite3 error:
if i reboot the system it won’t go back to life.
I use Knx and mqtt sensor, i first tought that in the develloping phase i was too often rebooter Hass.io but that last time i installed HA i’ve gone for 2 week on holidays without making any changes to be sure to be able to manage the house beeing away, but the error come back anyway.
Does someone have experianced the same error ?
I think the database home_assistant_v2.db is corrupted. you can safely delete this file and restart. (all saved history is purged by doing this)
I’m not sure his problem is just the database.
He also gets an error “Saving JSON file failed: /config/.storage/auth”
This seems like a corrupt SD Card to me.
the file “home_assistant_v2.db” doesn’t exist in my folder …
That can explain why after at least 3/4 fresh installation i still get the error after a while …
