Home_assistant.call_service.turn_on
I was wondering which domains were supposed to be supported by this?
Obviously lights and switches, but what about covers, locks, etc. The UI lets you call this on a cover/lock, but it doesn’t seem to do anything. Is this intended functionality?
I would have assumed turn_on would correspond to cover.open and lock.lock.
The service is homeassistant.turn_on.
It only works on domains that have the states on and off. So not covers or locks.
The UI lets you do many things you should not. You could write a blog in the yaml editor for example (no one should ever write a blog).
Should I log this as an issue against the UI?
Probably not. Filtering the available services based on the selected entity is more of a feature request. You can do that in the Github HA frontend Discussions.
However there are issues with doing this that would need to be considered:
What if the user selects an area?
What if the service is selected before the entity?
