Since upgrading to 0.95.x, I can no longer sync devices to Google via the Cloud component. Everything has worked flawlessly up to this point. Now, when I try to sync from either Home Assistant or via “sync my devices” on Google Assistant on my phone, I get errors and new devices do not sync.
My log shows this error each time:
2019-06-28 07:28:43 ERROR (MainThread) [homeassistant.components.google_assistant.smart_home] Unexpected error
File "/usr/src/app/homeassistant/components/google_assistant/smart_home.py", line 55, in _process
result = await handler(hass, data, inputs[0].get('payload'))
File "/usr/src/app/homeassistant/components/google_assistant/smart_home.py", line 86, in async_devices_sync
async_get_entities(hass, data.config)
File "/usr/src/app/homeassistant/components/google_assistant/helpers.py", line 119, in sync_serialize
entity_config = self.config.entity_config.get(state.entity_id, {})
AttributeError: 'NoneType' object has no attribute 'get'
2019-06-28 07:28:43 ERROR (MainThread) [homeassistant.components.google_assistant.smart_home] Error handling message {'inputs': [{'intent': 'action.devices.SYNC'}], 'requestId': '1967247859201571938'}: {'errorCode': 'unknownError'}
My phone just says there was an error syncing to hass.io.
I have attempted numerous restarts and even went as far as unlinking hass.io, but now it wont re-link. When I try to re-link it, it just says “Couldn’t update the setting, please check your connection.” There are no connection issues. I tried multiple times including ensuring it was unlinked, restarting Hass, and waiting 30 minutes to let everything sync up. Same error.
This morning, I tried to wipe out my cloud settings altogether (removed cloud file from .storage) and restarting Home Assistant. Then I signed back into Nabu Casa, selected my entities for Google, then tried linking hass.io on my phone. Same error.
I’m not sure what else to try at this point. Anyone have any ideas whats going on?
I will try downgrading later on to see if that helps.
