Home assistant Cloud reports connected, Nabu Casa reports offline
after some power issues today I have connectivity problems. Home Assistant reports that the Cloud is connected, in my Nabu Casa account it says offline. Alexa is not working reporting that the device a currently not reacting. I could connect from my home PC a while ago (using the habu casa URL) but now it's not working, on my Android phone the App doesn't connect as well. What can I do?
Thanks,
Thomas
Hi, the only thing you can do is to restart HA and give it some time.
Hi...
Thanks, restarting didn't help, but I found the reason... I don't know why but somehow my router assigned the same IP address to HA and my Smartphone... Changed the IP and everything worked again...
Thomas
Good that you got it solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
