Snap bro was just start looking into this
same, cant open webui, ragardless or ip or domain name etcā¦
Thanks for sharing the code. Got my data in
How often will the RESTful API load data?
Wondering if inserting some extra lines is smart to not spam foldingathome.org
E.g. scan_interval: 600
But then at the docs page
it says:
Note: These options are being phased out and are only available for single platform integrations.
Does that mean that I shouldnāt use it?
Also, as a Home Assistant beginner ā would it be smart to also add force_update
for graph possibility, or would that be irrelevant?
found the rank one
- platform: rest
resource: https://stats.foldingathome.org/api/donor/myle
name: Folding at Home Work Rank
value_template: '{{ value_json.rank }}'
Hi all,
Is there any way to control the folding from an automation, for instance I want my folding pc to lower the folding to low or stop it overnight?
Any way of utilizing my Google coral edge tpu?
I created a custom component for that: https://github.com/eifinger/hass-foldingathomecontrol.
It offers services to pause/unpause the folding.
Hi frenck, does this Folding@home ARM support means we will have Folding@home Add-on support for our Raspberry Piās?
Any chance of adding ingress support for the web interface?
I am having some problems with your integration: I am running Folding@home as add-on and got this issue
although (i guess) i correctly configured the add-on enabling remote control
It looks like my integration is working as intended. Is anyone else seeing this behavior when using this addon with my integration?
I can confirm I canāt solve the issue although all seems to work
but consistently sensors goes to āunavailableā for a second and then come back online
