It require spotify premium account?
Yes, is does require that
Sure? Now with Spotify free, you can also make use of Spotify connectā¦ That changed about half year agoā¦
I know some amplifiers got an API uodate, so you could also use a free account to use Spotify connect
Is there anyway to use alsamixer with this addon?
I canāt modify the spotify_asound file because the addon always overwrite them,and i have to use the āalsamixer sound cardā not the hardware card directly.
āThe equalization works only when the application uses the default output device from asound.conf. Applications that are configured to use the hardware device directly (you might see āhw:0ā or similar in the command line options or in the configuration file) wonāt use the equalization plugin.ā
Thanks,
same question here: How can I send a command to the addon from hass.io (e.g. via MQTT: Start - Stop - Next Song - Play specific song, ā¦)
Iād like to wake up to my favorite spotify playlistā¦
Release v0.7.0
This general maintenance release.
Changes
- Upgrades Spotifyd to 0.2.20
- Upgrades libssl-dev to 1.1.1-1ubuntu2.1~18.04.5
- Updates maintenance/license year to 2020
- Adjust add-on installation instructions
- Funding adjustments
- Fixes some spelling and grammar
- Upgrades add-on base image to v4.0.3
- Upgrades cargo to 0.38.0-0ubuntu1~18.04.1
- Upgrades git to 1:2.17.1-1ubuntu0.5
- Upgrades rustc to 1.37.0+dfsg1+llvm-1ubuntu1~18.04.1
- Fix login issue, allow discovery mode
- Update add-on documentation for discovery mode
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work:
https://github.com/sponsors/frenck or https://patreon.com/frenck
Intel nuc Is supported ?
Yes it is.
How to make it
Level 1: Play/Pause
Level 2: Change Volume, Change Tracks
Level 3: Play a specific song or playlist
via hass.io / automations / actions?
Using the Spotify Integration.
Do you mean that I need to open Spotify on another device in order to control it? Thatās how I do it now, but the added value is limited.
Iād rather have an automation set up in hass.io, so that for example when I come home, the music turns on, when I leave the house it turns off, etc.
If the Spotify Integration is a different application/addon, Iād be thankful for a link.
Thanks a lot for you great work on hass!
Release v0.7.1
Changes
- Upgrades spotifyd to v0.2.22
Hey @frenck,
thanks for this awesome add-on. Itās working perfectly. Only one thing though:
When I try to replace my spotify credentials in the config with !secret spotify_username and !secret spotify_password, the editor does not let me save the config, since it an āInvalid YAMLā.
I suppose this could be an issue with the editor itself and not your add-on. But did anyone else also have this problem and is there potentially a workaround?
Thanks,
Tobias
Hi @frenck thanks for the great work on this and so many other awesome add-ons. Is it possible to add multiple accounts to the Spotify integration? We use 2 accounts at home and Iād like to add both.
Thanks.
Yes, just do the steps in the frontend multiple timesā¦
Hi @frenck,
It looks that this plugin is what I need in my new HA system based on RPi4 and hass.io image.
The system is running already but when I select Spotify Add-on and click on INSTALL after some 20-30 seconds I am getting the red āFailed to install addon, [object Object]ā error:
I cannot find anything in the normal logs related to this installation.
Any idea what I am possibly doing wrong or what need to do to install it ?
UPDATE 2h later.
It seems now that Add-on is installed (however I did not do anything) and I am able to put login/passwords and select Input and Output. However when I click on START nothing happens. Restart of hassio does not change anything.
UPDATE next day.
Idea came to me to uninstall and install again. And this time it worked with not errors and I was able to play music from HA RPi4 !
But what was initial problem I do not now.
Hi all, sorry maybe for the dumm question, but I installed the addon on my RP. Iāve configured with login and pwd the conf part, and if I start, in the logs, everything is ok.
The problem is now that I cannot understand how to add the player ā¦ could you give me some hints pls?
Hi SKAL.
There is no player as such in this case. Once you have this addon running you need to use Spotify on any other device (your phone, tablet, computer, ā¦) with the same user/password and once its running you will have an option to select āavailable devicesā (in case of Windows app it is next to volume control). Once you click on it you will be able to select āhass.ioā (or another name which you can enter in Add-on configuration file).
After you select it it, musisc you select will be played on the Add-on.
Thank you really much. I was getting crazy with that
Could you suggest me then an addon in order to integrate a spotify āmoduleā in the overview panel?
