Hi
I have been trying to log in from my phone and get the following error:
You’re about to give https://home-assistant.io/iOS access to your Home Assistant instance
Logging in with Home Assistant Local.
Error: invalid client id or redirect uri
This is showing on my logs
Error while looking up redirect_uri https://home-assistant.io/iOS: Cannot connect to host home-assistant.io:443 ssl:None [No route to host]
Login attempt or request with invalid authentication from 192.168.2.1
Here is the config on the app
CONNECTION
URL: https://myurl.duckdns.org
Use legacy authentication - off
Show advanced settings - off
On Advanced setting:
Use Internal URL - off
Basic Authentication - off
Can anyone help?
p
