Perfect ! But now I’m eager to see those updated without having to open the app too No hurry though, my main usage is to control HA via the watch. Related to this last point, do you know if there is room to improve latency / responsivness or is it as good as it gets ?
It would be brilliant for the watch sensor to update in the background! Maybe a pair of new apps (free and paid) just for the zepp 2.0? That way the other users using older os could still use something? I wouldnt mind paying again for version 2.0 full. Keep up the great work here!
I am pretty sure more and more features will keep coming. As we said, you can join our community to vote every ~10 days what do you want to see in the app!
Hey. I would like to know whether it is possible to use the app to use my Amazfit Balance as a presence device. Just like the smartphone.
Yes it is! You can use it with Bermuda (i do it) or ESPresense.
Indeed we are working in specific features working with Bermuda (coming soon)
Thanks! I will take a look at it.
I have this up and running on my Amazfit Active 2. Its working well except for 2 issues.
- Fonts too small, especially on display of sensor data. Unreadable to me without a magnifying glass.
- In looking at the states data for Amazfit on Home Assistant, the only thing I see is next alarm, next reminder, next timer, and do not disturb switch. I expected to see a lot more. Is the active 2 on your list of supported devices?
I found the rest of the data on number 2 above, the entity filter needed to be set to “watch”.
So the only thing is the tiny fonts.
I confirm that in Amazfit Active 2 the sensor values are unreadable due to the font being too small and faded.
In the coming updates you will be able to increase the font size
Unfortunately I can’t find a trace of the smartwatch sensors in HA.
Have you seen this?
NEW UPDATE!!
Buttons entites are supported now
Found! I was looking for “amazifit” as I had read before.
To read all the data in a Lovelace tab what advice?
Maybe it would have been better to have a sensor for each attribute that refers to the “watch” device.
I set up a “helper” in Home assistant, based on a template. Then the helper shows up as entity. For example, the battery % I used:
{{ state_attr(“sensor.active_2_round_crandy2”, “battery_state”) }}
You would have to set up separate helpers for each value you want
Small fonts are also a problem with buttons. Looking forward to the update that let’s us size fonts.
It was tested that way, but it was necessary to make an https request per sensor, and because there were so many sensors, some of them failed, so it was decided to make a single request with all the attributes for a better experience.
We are working on it, we had it but with large sizes in some languages it was out of size and not readable.
By installing from HACS multiple-entity-row it is possible to create a custom tab that shows all the attributes in a readable way.
Here’s how to configure (the labels are in Italian):
type: entities
title: Stato Watch
show_header_toggle: false
entities:
entity: sensor.watch
type: custom:multiple-entity-row
icon: mdi:battery
show_state: true
entities:- attribute: battery_state
unit: “%”
icon: mdi:heart-pulse
show_state: true
entities:- attribute: heart_state
unit: bpm
name: Distanza e Passi
icon: mdi:walk
show_state: true
entities:- attribute: distance_state
unit: m - attribute: steps_state
unit: steps - attribute: steps_daily_target
name: Stand e Attività
icon: mdi:human-handsup
show_state: true
entities:- attribute: stand_state
name: Ore in piedi
unit: h - attribute: stand_hours_target
name: Obiettivo - attribute: fat_burning_state
unit: min - attribute: fat_burning_minutes_target
name: Calorie e Temperatura
icon: mdi:fire
show_state: true
entities:- attribute: calorie_state
unit: kcal - attribute: calories_burnt_target
name: Obiettivo - attribute: temperature_state
unit: °C
icon: mdi:chart-line
show_state: true
entities:- attribute: pai_state
unit: pai - attribute: pai_total
icon: mdi:sleep
show_state: true
entities:- attribute: sleep_state
unit: min - attribute: sleep_score
name: Punteggio - attribute: sleep_deep_minutes
icon: mdi:lungs
show_state: true
entities:- attribute: spo2_state
unit: “%”
icon: mdi:database
show_state: true
entities:- attribute: disk_total
unit: Mb - attribute: disk_free
unit: Mb - attribute: disk_app
unit: Mb - attribute: disk_watchface
unit: Mb
