Home assistant control kaku switch
I am new with programming home assistant and need a little bit help.
To control the kaku with putty it works. See picture below.
KakuCommand
sudo ./newkaku 123 1 on
But now my problem, i can’t get the code correct in the home assistant (configuration.yaml).
I have tried things like below:
switch:
•platform: command_line
switches:
kitchen_light:
command_on: sudo ./newkaku 123 1 on
command_off: sudo ./newkaku 123 1 off
Can anyone help me with the configuration.yaml?
Thank you very much.
Erwin
