Home assistant core update 2026.6 stops at 35 - 48 % of the update process
The core update 2026.6 on my home assistant system on a RPi4 stops at 35 - 48 % of the proces. Without an error message.
Installed core is 2026.5.4.
Do you have enough free space? Try to follow the supervisor logs while you do this via ha supervisor logs -vf.
Hi Bram, are you talking about the core component with a HAOS setup or core in venv?
core in HAOS
In the log I saw some yellow warning lines. To be sure I ran the update again. And of course it ended normally. with the new core installed.
There were some still some warning lines in the log:
2026-06-06 12:03:17.826 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:17.817 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412785-if00
2026-06-06 12:03:17.833 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:17.830 WARNING (MainThread) [supervisor.homeassistant.module] Can't get Home Assistant Core configuration: Can't connect to Home Assistant Core WebSocket, the API is not reachable. Not sending hardware events to Home Assistant Core.
2026-06-06 12:03:17.838 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:17.836 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/015 - None
2026-06-06 12:03:20.137 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:20.129 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/016 - None
2026-06-06 12:03:20.137 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:20.132 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412785-if00
2026-06-06 12:03:20.144 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:20.143 WARNING (MainThread) [supervisor.homeassistant.module] Can't get Home Assistant Core configuration: Can't connect to Home Assistant Core WebSocket, the API is not reachable. Not sending hardware events to Home Assistant Core.
2026-06-06 12:03:21.398 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:21.395 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412785-if00
2026-06-06 12:03:21.412 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:21.408 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/016 - None
2026-06-06 12:03:21.414 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:21.412 WARNING (MainThread) [supervisor.homeassistant.module] Can't get Home Assistant Core configuration: Can't connect to Home Assistant Core WebSocket, the API is not reachable. Not sending hardware events to Home Assistant Core.
2026-06-06 12:03:23.811 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:23.810 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/017 - None
2026-06-06 12:03:23.817 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:23.815 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM0 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2412785-if00
2026-06-06 12:03:23.824 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:23.823 WARNING (MainThread) [supervisor.homeassistant.module] Can't get Home Assistant Core configuration: Can't connect to Home Assistant Core WebSocket, the API is not reachable. Not sending hardware events to Home Assistant Core.
2026-06-06 12:03:25.109 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:25.104 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2026-06-06 12:03:25.325 homeassistant hassio_supervisor[653]: 2026-06-06 14:03:25.323 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
Conbee issues?
