Home Assistant - Couple of errors im having issues with
Hi All
I am having a couple of strange errors.
Basic install (fresh)
Node-red installed
HACS - Installed, but still sitting there trying to start up (been hours, and rebooted multiple times)
However i am getting these errors in the logs, any help would be greatly appreciated.
20-12-04 14:57:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
20-12-04 15:00:58 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
20-12-04 15:00:58 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-12-04 15:01:03 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
and also
20-12-04 13:59:05 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62603 ssl:default [Connect call failed (‘172.30.32.1’, 62603)]
20-12-04 13:59:07 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62603 ssl:default [Connect call failed (‘172.30.32.1’, 62603)]
I’m having exactly the same issue with HA 1.0.0 b1.
Thanks, i’ve just upgraded again, and the errors seem to have gone away, although node-red work flows still are not working. (i’m going to assume thats a different issue and troubleshoot)
