i’ve recently experienced a crash of home assistant with this log
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1146, in create_connection
sock = await self._connect_sock(
exceptions, addrinfo, laddr_infos)
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1045, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
return await fut
asyncio.exceptions.CancelledError: Home Assistant is stopping
It crashed!
I’m assuming network issues.
There should be more clues surrounding this error message, otherwise restart in safe mode and see if there are any apps or add-ons that are causing issues.
Are you up to date with all updates?
What was the last two things you changed?
Sadly “Make your Home Assistant UI feel instantly responsive!” and “with automatic self-correction” may be a misnomer, especially as it hasn’t been updated in a few months. Raise an issue on GitHub if it is the culprit.
