Home Assistant Dashboard - Way to automatically update when new entities got added to ESPHome / MQTT Device
I am a bit unsure how to phrase this …
To show the newly added ESPHome Entities (I am using esphome-jk-bms from syssi as well as esphome-jk-bms-can from Sleeper85 Repositories), I usually go to:
Settings → Devices & Services → Integrations → MQTT → Devices
Then I would go into the Device I am interested in an click on the “Add to Dashboard” for each Block / Section of Configuration/Sensors/Numbers I am interested in.
This work correctly.
The problem (or feature) is that, if I do a code change in the ESPHome YAML file adding (exposing) some extra entities, reflashing the ESP32 and Rebooting, these do NOT show up in the Dashboard I had created.
Instead, I usually end up creating a new Dashboard (sigh) and re-to the whole procedure:
Then I would go into the Device I am interested in an click on the “Add to Dashboard” for each Block / Section of Controls/Sensors/Diagnostic I am interested in.
Rinse and repeat …
Is there a way to “link” these ESPHome “Blocks” so that, whener I add a new entity / sensor / number to the ESPHome YAML file, the Home Assistant Lovelace Dashboard is automatically updated to include this new sensor / number / switch / etc ?
