I am pretty new to Home Assistant. I just installed hassio on a raspberry pi a few weeks ago and have been working on it on and off, with the goal of setting up a bunch of tasmota devices in. I was working through this tutorial last night and I got as far as installing mosquito and then left it. This morning when I tried to access Home Assistant from the usual IP:8123
path, browser says “connection was reset” and nothing loads. It looks like the server is down completely. Unfortunately, I do not have SSH or Samba setup yet. I took the SD card out and plugged into my Linux machine and I can see 4 mount points.
I am guessing, it there is any hope to recovery, it will be somewhere in the hassos-data
point. However, searching through all those nested folders, I am pretty lost and can not find my way. Here are my question:
- where can I find a log file that would tell me why the server is failing to load?
- how can I revert the mosquito installation to see if that is the issue?
- Where can I find and edit the
configuration.yaml
file, to see if I messed up something in there
Any tips or advice is much appreciated. Thank you!
