Hi there,
I have Home Assistant running on Proxmox 9.2.20 in a VM. Unfortunately, even my older backups will no longer start properly.
The CLI starts, and the web interface also becomes available, but then I get the “Connection lost. Reconnecting…” message. Home Assistant/HAOS never fully starts again. This also happens when I restore older backups that previously worked.
I also tried running the VM on another machine with Proxmox 9.2.11. In that setup, HAOS started successfully once, but after restarting the VM, I experienced exactly the same issue again.
I then created a completely new HAOS installation, and that works as expected.
At this point, I’m completely out of ideas. Does anyone have an idea what could be causing this or what I should check next?
Thanks in advance!
