### Describe the problem you are having
Frigate v0.12 crashes the whole serve…r every 1-2 days!
I have not eben able to record anything, because the homeassistant server dies compleatly.
Right before the crash no memory or ram problems can be observed. The only thing is that the crashes seem to be occouring in the early morning every time, baut maybe this is just bad luck!
PC is a core I5 Intel cpu with 8 gig ram.
### Version
v0.12
### Frigate config file
```yaml
mqtt:
# Required: host name
host: xxx
user: xxx
password: xxx
# Optional: port (default: shown below)
port: 1883
detectors:
cpu1:
type: cpu
num_threads: 1
cpu2:
type: cpu
num_threads: 1
cpu3:
type: cpu
num_threads: 1
birdseye:
enabled: True
mode: continuous
quality: 3
live:
# Optional: Set the height of the live stream. (default: 720)
# This must be less than or equal to the height of the detect stream. Lower resolutions
# reduce bandwidth required for viewing the live stream. Width is computed to match known aspect ratio.
height: 1080
# Optional: Set the encode quality of the live stream (default: shown below
# 1 is the highest quality, and 31 is the lowest. Lower quality feeds utilize less CPU resources.
quality: 2
record:
enabled: True
expire_interval: 1
# Optional: Retention settings for recording
retain:
# Optional: Number of days to retain recordings regardless of events (default: shown below)
# NOTE: This should be set to 0 and retention should be defined in events section below
# if you only want to retain recordings of events.
days: 0
# Optional: Mode for retention. Available options are: all, motion, and active_objects
# all - save all recording segments regardless of activity
# motion - save all recordings segments with any detected motion
# active_objects - save all recording segments with active/moving objects
# NOTE: this mode only applies when the days setting above is greater than 0
mode: all
events:
pre_capture: 20 # Optional: Number of seconds before the event to include (default: shown below)
# Optional: Number of seconds after the event to include (default: shown below)
post_capture: 10
# Optional: Objects to save recordings for. (default: all tracked objects)
objects:
- person
- car
# Optional: Retention settings for recordings of events
retain:
# Required: Default retention days (default: shown below)
default: 5
# Optional: Mode for retention. (default: shown below)
# all - save all recording segments for events regardless of activity
# motion - save all recordings segments for events with any detected motion
# active_objects - save all recording segments for event with active/moving objects
mode: active_objects
# Optional: Per object retention days
objects:
person: 5
car: 1
snapshots:
# Optional: Enable writing jpg snapshot to /media/frigate/clips (default: shown below)
# This value can be set via MQTT and will be updated in startup based on retained value
enabled: True
# Optional: save a clean PNG copy of the snapshot image (default: shown below)
clean_copy: True
# Optional: draw bounding box on the snapshots (default: shown below)
bounding_box: True
# Optional: crop the snapshot (default: shown below)
crop: False
# Optional: Restrict snapshots to objects that entered any of the listed zones (default: no required zones)
required_zones: []
# Optional: Camera override for retention settings (default: global values)
retain:
default: 5
objects:
person: 5
car: 1
cameras:
Cam0:
rtmp:
enabled: False
ffmpeg:
inputs:
- path: rtsp://???/stream2 # <-- 102 substream
roles:
- detect
- path: rtsp://???/stream1 # <-- 101 mainstream
roles:
- record
detect:
width: 1920
height: 1080
fps: 5
objects:
track:
- person
filters:
person:
min_area: 10500
max_area: 130000
max_ratio: 0.58
min_ratio: 0.2
zones:
frigate_Sitzplatz:
coordinates: 1134,1080,1920,1080,1920,292,1729,265,1712,0,1388,0,1387,280,1458,281,1505,335,1501,407,1494,478,1383,476,1299,466,1308,334,1363,286,1369,0,1122,0
frigate_Sudseite:
coordinates: 1168,1080,484,1080,412,0,1141,0
frigate_Westseite:
coordinates: 0,1080,504,1080,414,42,0,0
motion:
mask:
- 707,53,707,0,0,0,0,54
- 1320,268,1432,267,1531,278,1574,314,1564,445,1489,515,1405,515,1266,487,1282,286
- 1228,350,1238,491,1053,548,1003,373
Cam1:
rtmp:
enabled: False
ffmpeg:
inputs:
roles:
- detect
roles:
- record
detect:
width: 1920
height: 1080
fps: 5
motion:
mask:
- 706,0,710,84,0,113,0,0
Cam2:
rtmp:
enabled: False
ffmpeg:
inputs:
- path: rtsp://??? # <-- 102 substream
roles:
- detect
- path: rtsp://??? <-- 101 mainstream
roles:
- record
detect:
width: 2592
height: 1944
fps: 5
motion:
mask:
- 2554,1846,2560,1899,1904,1897,1904,1829
- 0,392,156,375,279,350,386,320,576,269,595,220,605,41,0,90
- 1392,0,1398,168,915,164,900,0
- 2445,51,2426,264,2123,207,2057,0
- 1963,105,1955,318,1405,292,1403,79
objects:
track:
- person
- car
zones:
frigate_Eingang_vorne:
coordinates: 0,439,228,352,328,369,443,360,563,341,428,533,0,799,0,795
objects:
- car
- person
frigate_Garage_Abfahrt_vorne:
coordinates: 546,362,0,833,0,1420,0,1944,222,1944,929,347
objects:
- car
- person
frigate_Garten_vorne:
coordinates: 249,1417,2571,1944,2592,786,2560,616,2407,446,1985,379,848,339
objects:
- car
- person
frigate_Strasse_vorne:
coordinates: 0,388,192,345,397,301,625,262,980,224,1522,241,2373,328,2592,390,2592,0,0,0
objects:
- car
- person
stationary:
max_frames:
objects:
car: 1000
ffmpeg:
hwaccel_args: -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p
output_args:
record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
### Relevant log output
```shell
none available
### Frigate stats
_No response_
### Operating system
Debian with Homeassistant Supervised / Docker
### Install method
HassOS Addon
### Coral version
CPU (no coral)
### Any other information that may be helpful
v0.11 does work with on problem.
