Hi everyone — I’m sharing HA Git Sync, a template-focused workflow to keep Home Assistant config reproducible, auditable, and easier to recover.
What it does
- Bi-directional sync model between
/configand GitHub. - Optional GitHub Actions automations for upstream template sync and alias autocorrection PRs.
- Security-first defaults: optional features are off by default, and branch-protection-friendly checks are expected.
Why I built it
I wanted a setup that reduces config drift and keeps recovery straightforward after bad edits or failed merges. This project aims to make that easy for first-time users while still being maintainable long-term.
Start in about a minute
- Use the template and clone to
/config. - Configure Git auth (SSH or fine-grained token).
- Merge the example HA snippets.
- Run
bash scripts/git_sync.sh. - Confirm checks pass in GitHub.
Docs:
- Quick start:
docs/quickstart.md - Security:
docs/security.md - Troubleshooting:
docs/troubleshooting.md
Feedback is welcome — especially around edge cases in different Home Assistant installation modes.
60-second getting-started snippet
git clone [email protected]:<your-user>/<your-repo>.git /config
cd /config
bash scripts/install_git_hooks.sh
bash scripts/git_status.sh
Known limitations and trade-offs
- Merge conflicts still require manual resolution.
- Quality of automation alias correction depends on your naming conventions.
- Workflow behaviour relies on repository permissions and branch protection setup.
Feedback request CTA
If you try this, please share:
- Your Home Assistant install type (OS/Container/Supervised/Core)
- Any setup steps that felt unclear
- Which guardrails you want enabled by default vs optional
