Home Assistant Green + PostgreSQL
Hi there,
Currently I run Home Assistant on an Intel NUC running Ubuntu in Docker, which works fine, but I look into replacing the NUC with a HA Green.
I use PostgreSQL as log storage database.
As I understood, HA Green is meant to be more of a plug-and-play “appliance”.
It is possible to install PostgreSQL on the HA Green and use it ?
Or would I be better off installing PostgresSQL on a separate host in my network ?
Thank you in advance.
