Home assistant, how to access aqara m2 hub airconditioner
I have 2 Aqara Hubs. M2 hub international (not china) & the M3 hub. I have connected both these Hubs to Aqara App, & home assistant Via HomeKit & Matter,
I have the Aqara Hub M3 with Airconditioner (AC) In the livingroom. this shows OK in Aqara App & Home assistant
The M2 is in the bedroom and can control the AirConditioner (AC) directly from the Aqara app. however I can not find the AC in Home assistant
Anybody know how I can add the AC from M2 to home assistant
I have an update.
I can now access the Aircon on Aqara hub M3 by removing it from home assistant reset the Aqara hub, add the Aircon then add back to homeassistant, now it shows and is accessible
However this wont work on the Hub M2
Has anybody any method that will work
I tried adding them through HomeKit but same situation
I finnaly found a way to do it.
Thanks to ellite Miguel Ribeiro
Create your scenes on the Aqara app. Then go to your profile on the Aqara app and tap on connect to ecosystems. Then select home assistant and then Scene and signals sync and finally on Scene sync.
Then you can select which scenes you want to send to home assistant. then add again to Homeassistant with Matter
