Thanks for allowing me to join.
I have just tried to see if my topic is in the existing posts, but so far I have been unable to see anything matching my problem, thus seeking help please.
I just used my windows 11 computer, followed this video https://www.youtube.com/watch?v=kX4t6D8v0GE on how to setup.
It all went perfectly, I then went to lunch, and shut down my machine beforehand.
On return, I tried to run my Home Assistant again, by clicking the Oracle VirtualBox icon on my desktop
When I do so,Oracle VirtualBox manager opens, however on the left side column, it says “HomeAssistant” inaccessible, with this data
Runtime error opening ‘C:\Users\Admin\Desktop\HA$$VM\HomeAssistant\HomeAssistant.vbox’ for reading VERR_FILE_NOT_FOUND (File not found.).
D:\tinderboxa\win-7.1\src\VBox\Main\src-server\MachineImpl.cpp[984] (long __cdecl Machine::i_registeredInit(void)).
Result Code:
E_FAIL (0x80004005)
Component:
MachineWrap
Interface:
IMachine {e36a5081-a82a-40bd-9e4e-42a44d6ce50f}
If I also run the IP address of 192.168. x.xxx:8123 in a browser(which worked before) I then get the message "This site can’t be reached
192.168.5.xxx took too long to respond.
Perhaps I closed the application in the wrong manner and upset things?
I also tried a google search, on the correct manner to open Home Assistant on a windows machine, once installed, but again I could not find the correct process, only help guides on how to install via VirtualBox. Perhaps I am not starting correctly?
As a newbie, I am lost…can anyone assist me please?
THANK YOU
