I upgrade my HA instance on RPi3 with the following command:
sudo hassbian-config upgrade homeassistant
The output I get is shown below with my comments in italics I have always had a couple of errors but my systems ran well, since 0.75.1 its been decidedly dicey so need to have a check to see if there is anything that needs attention:
Home Assistant install script for Hassbian.
Copyright© 2017 Fredrik Lindqvist https://github.com/Landrash.
Checking current version
You are using pip version 10.0.1, however version 18.0 is available. I have installed pip and updated but error remains the same so I assume this is embedded, I am also assuming this is not an issue
You should consider upgrading via the ‘pip install --upgrade pip’ command.
Stopping Home Assistant
Changing to the homeassistant user
Changing to Home Assistant venv
Installing latest version of Home Assistant
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: setuptools in /srv/homeassistant/lib/python3.5/site-packages (40.0.0)
Requirement already up-to-date: wheel in /srv/homeassistant/lib/python3.5/site-packages (0.31.1)
python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you’ll have pycryptodome 3.4.11 which is incompatible. Is this something I can resolve or should be concerned about?
Requirement already up-to-date: homeassistant in /srv/homeassistant/lib/python3.5/site-packages (0.75.2)
Requirement not upgraded as not directly required: pip>=8.0.3 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (10.0.1)
Requirement not upgraded as not directly required: jinja2>=2.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.10)
Requirement not upgraded as not directly required: astral==1.6.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (1.6.1)
Requirement not upgraded as not directly required: voluptuous==0.11.5 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (0.11.5)
Requirement not upgraded as not directly required: pytz>=2018.04 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2018.5)
Requirement not upgraded as not directly required: attrs==18.1.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (18.1.0)
Requirement not upgraded as not directly required: certifi>=2018.04.16 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2018.4.16)
Requirement not upgraded as not directly required: requests==2.19.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.19.1)
Requirement not upgraded as not directly required: pyyaml<4,>=3.13 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.13)
Requirement not upgraded as not directly required: aiohttp==3.3.2 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.3.2)
Requirement not upgraded as not directly required: async-timeout==3.0.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.0.0)
Requirement not upgraded as not directly required: MarkupSafe>=0.23 in /srv/homeassistant/lib/python3.5/site-packages (from jinja2>=2.10->homeassistant) (1.0)
Requirement not upgraded as not directly required: idna<2.8,>=2.5 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.19.1->homeassistant) (2.6)
Requirement not upgraded as not directly required: chardet<3.1.0,>=3.0.2 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.19.1->homeassistant) (3.0.4)
Requirement not upgraded as not directly required: urllib3<1.24,>=1.21.1 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.19.1->homeassistant) (1.22)
Requirement not upgraded as not directly required: yarl<2.0,>=1.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.3.2->homeassistant) (1.2.5)
Requirement not upgraded as not directly required: multidict<5.0,>=4.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.3.2->homeassistant) (4.3.1)
Requirement not upgraded as not directly required: idna-ssl>=1.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.3.2->homeassistant) (1.0.1)
python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you’ll have pycryptodome 3.4.11 which is incompatible. Again I assume this is not an issue but would appreciate confirmation
Deactivating virtualenv
Restarting Home Assistant
Checking the installation…
Upgrade complete…
Note that it may take some time to start up after an upgrade.
FYI I am now running 0.75.2 and issues remain the same.
Thanks in advance.
