I have always installed home assistant os for friends on different Odroid boards in the past few years.
However, recently and in more than few occasions we have problems.
on previous version 13.1 if i installed and set up at my address and then took it to my friends house to use it it will not assign IP address or gets picked up or on “http://homeassistant.local:8123/” screen just say connection error, but if I reimage the EMMC and start over, it will go through the setting up with no problem, but then if I restart it the same problem happens.
I was hoping a new release of the OS will sort this out, but when this was released last week it was fine on friday, however today the software would not even loads completely and keeps timing out and loops back.
I should say I am not that much expert on any of this and just use this as a standard plug in and set up which mostly works and I have done it for at least 7 or 8 friend in the past couple of years.
but in the past few weeks i am stock with this one unit and dont know if I am doing something wrongor not.
I have used the guide step by step without any fail maybe 20 times but no luck.
Can anyone help at all?
