Hello.
So I have been having this issue since about November that my Home Assistant becomes unresponsive and requires a hard restart when I have ZHA enabled. If I disable ZHA it doesn’t happen. I have tried removing every ZigBee device and tried a different ConBee II stick. Home Assistant won’t survive 24 hours if it is enabled.
Im pretty new to home automation and I don’t know how I could troubleshoot this further. Logs show nothing when it crashes and just stop when it happens.
I tried it and the crashing still happens.
There is nothing in the logs. The last sensor update I got before it crashed was sent at 05:10:09 last night.
2023-03-04 16:37:01.846 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-04 16:37:01.848 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-04 16:37:21.334 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sahkonhinta_porssi_snt (<class 'custom_components.nordpool.sensor.NordpoolSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
2023-03-04 16:37:24.175 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.sahkonhinta (<class 'custom_components.nordpool.sensor.NordpoolSensor'>) is using state class 'measurement' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
2023-03-04 17:10:32.966 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ilp_lampotila is taking over 10 seconds
2023-03-04 17:37:06.176 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://accounts.nabucasa.com/payments/subscription_info (401)
2023-03-04 17:37:06.185 ERROR (MainThread) [homeassistant.components.cloud.subscription] Failed to fetch subscription information
2023-03-04 18:10:33.110 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ilp_lampotila is taking over 10 seconds
2023-03-04 19:10:33.363 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-04 20:10:33.403 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ilp_lampotila is taking over 10 seconds
2023-03-04 22:10:33.578 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-04 23:10:33.650 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-05 00:10:33.719 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-05 01:10:33.783 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-05 02:10:33.855 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-05 03:10:33.929 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ilp is taking over 10 seconds
2023-03-05 03:20:58.927 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 139-162-37-118.ip.linodeusercontent.com (139.162.37.118). Requested URL: '/media/wp-includes/wlwmanifest.xml'. (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36)
2023-03-05 04:10:34.447 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ilp_lampotila is taking over 10 seconds
