My HAOS will stop responding randomly (6 hours - 18 hours, 3 days between events). This only started within the past couple of weeks. Currently installed on a Dell Wyse 5070 with 8GB ram, running off an external SSD -
- Core2025.11.1
- Supervisor2025.11.2
- Operating System16.3
I’ve tried restoring from backups, disabling new add ons, nothing seems to help. It just went down a few hours ago, was still able to ping it from my router.
Here’s an example from a few weeks ago. The logs just stop and I will pull the plug and reboot the pc -
36m2025-11-04 03:28:16.238 DEBUG (MainThread) [zigpy.topology] Scanning neighbors of <Device model='WG001-Z01' manuf='AL001' nwk=0x642E ieee=94:b2:16:ff:fe:07:e1:32 is_initialized=True>e[0m
e[36m2025-11-04 03:28:16.239 DEBUG (MainThread) [zigpy.util] Tries remaining: 3e[0m
e[36m2025-11-04 03:28:16.319 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2025, 11, 4, 9, 28, 16, 318924, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x642E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32817, data=Serialized[b'\x05\x00\x04\x00\x03\x08\x9a\t\xff\xff.!\x00\x08\x9a\t\xff\xff.!\x00\x00\x00$\x02\x00o\x08\x9a\t\xff\xff.!\x00\x8b\xf3R*\x00K\x12\x00s\x04%\x02\x0fF\x08\x9a\t\xff\xff.!\x00\xf2yc*\x00K\x12\x00\x03j\x05\x02\x0f\x89'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=248, rssi=-70)e[0m
e[36m2025-11-04 03:28:17.469 DEBUG (MainThread) [zigpy.util] Tries remaining: 3e[0m
e[36m2025-11-04 03:28:17.496 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2025, 11, 4, 9, 28, 17, 496869, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x642E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32817, data=Serialized[b'\x06\x00\x04\x03\x01\x08\x9a\t\xff\xff.!\x00\xb2\xd2\xc2\xfe\xff"\xfdlC\xed%\x02\x0fS'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-70)e[0m
e[36m2025-11-04 03:28:18.510 DEBUG (MainThread) [zigpy.topology] Scanned neighbors of <Device model='WG001-Z01' manuf='AL001' nwk=0x642E ieee=94:b2:16:ff:fe:07:e1:32 is_initialized=True>: [Neighbor(extended_pan_id=00:21:2e:ff:ff:09:9a:08, ieee=00:21:2e:ff:ff:09:9a:08, nwk=0x0000, device_type=<DeviceType.Coordinator: 0>, rx_on_when_idle=<RxOnWhenIdle.On: 1>, relationship=<Relationship.Sibling: 2>, reserved1=0, permit_joining=<PermitJoins.Unknown: 2>, reserved2=0, depth=0, lqi=111), Neighbor(extended_pan_id=00:21:2e:ff:ff:09:9a:08, ieee=00:12:4b:00:2a:52:f3:8b, nwk=0x0473, device_type=<DeviceType.Router: 1>, rx_on_when_idle=<RxOnWhenIdle.On: 1>, relationship=<Relationship.Sibling: 2>, reserved1=0, permit_joining=<PermitJoins.Unknown: 2>, reserved2=0, depth=15, lqi=70), Neighbor(extended_pan_id=00:21:2e:ff:ff:09:9a:08, ieee=00:12:4b:00:2a:63:79:f2, nwk=0x6A03, device_type=<DeviceType.Router: 1>, rx_on_when_idle=<RxOnWhenIdle.On: 1>, relationship=<Relationship.Parent: 0>, reserved1=0, permit_joining=<PermitJoins.Unknown: 2>, reserved2=0, depth=15, lqi=137), Neighbor(extended_pan_id=00:21:2e:ff:ff:09:9a:08, ieee=6c:fd:22:ff:fe:c2:d2:b2, nwk=0xED43, device_type=<DeviceType.Router: 1>, rx_on_when_idle=<RxOnWhenIdle.On: 1>, relationship=<Relationship.Sibling: 2>, reserved1=0, permit_joining=<PermitJoins.Unknown: 2>, reserved2=0, depth=15, lqi=83)]e[0m
e[36m2025-11-04 03:28:18.512 DEBUG (MainThread) [zigpy.topology] Scanning routing table of <Device model='WG001-Z01' manuf='AL001' nwk=0x642E ieee=94:b2:16:ff:fe:07:e1:32 is_initialized=True>e[0m
e[36m2025-11-04 03:28:18.513 DEBUG (MainThread) [zigpy.util] Tries remaining: 3e[0m
e[36m2025-11-04 03:28:18.545 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2025, 11, 4, 9, 28, 18, 545842, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x642E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32818, data=Serialized[b'\x07\x00\x10\x00\x0f\x00\x00\x10\x00\x00C\xed\x00C\xeds\x04\x00s\x04\x03j8\x03jA\xcc\x00C\xed\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00\x00\x00\x03\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-70)e[0m
e[36m2025-11-04 03:28:19.955 DEBUG (MainThread) [zigpy.util] Tries remaining: 3e[0m
e[36m2025-11-04 03:28:19.991 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2025, 11, 4, 9, 28, 19, 991272, tzinfo=datetime.timezone.utc), priority=None, src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x642E), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32818, data=Serialized[b'\x08\x00\x10\x0f\x01\x00\x00\x03\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-70)e[0m
e[36m2025-11-04 03:28:21.188 DEBUG (MainThread) [zigpy.topology] Scanned routes of <Device model='WG001-Z01' manuf='AL001' nwk=0x642E ieee=94:b2:16:ff:fe:07:e1:32 is_initialized=True>: [Route(DstNWK=0x0000, RouteStatus=<RouteStatus.Active: 0>, MemoryConstrained=0, ManyToOne=1, RouteRecordRequired=0, Reserved=0, NextHop=0x0000), Route(DstNWK=0xED43, RouteStatus=<RouteStatus.Active: 0>, MemoryConstrained=0, ManyToOne=0, RouteRecordRequired=0, Reserved=0, NextHop=0xED43), Route(DstNWK=0x0473, RouteStatus=<RouteStatus.Active: 0>, MemoryConstrained=0, ManyToOne=0, RouteRecordRequired=0, Reserved=0, NextHop=0x0473), Route(DstNWK=0x6A03, RouteStatus=<RouteStatus.Active: 0>, MemoryConstrained=1, ManyToOne=1, RouteRecordRequired=1, Reserved=0, NextHop=0x6A03), Route(DstNWK=0xCC41, RouteStatus=<RouteStatus.Active: 0>, MemoryConstrained=0, ManyToOne=0, RouteRecordRequired=0, Reserved=0, NextHop=0xED43)]e[0m
e[36m2025-11-04 03:28:21.190 DEBUG (MainThread) [zigpy.topology] Scanning topology (15/16) of <Device model=None manuf=None nwk=0xCC41 ieee=00:15:8d:00:09:49:eb:58 is_initialized=True>e[0m
e[36m2025-11-04 03:28:21.190 DEBUG (MainThread) [zigpy.topology] Scanning topology (16/16) of <MagnetAQ2 model='lumi.sensor_magnet.aq2' manuf='LUMI' nwk=0xE325 ieee=00:15:8d:00:8b:5a:3b:7e is_initialized=True>e[0m
e[36m2025-11-04 03:28:21.190 DEBUG (MainThread) [zigpy.topology] Finished scanning neighbors for all devicese[0m
e[36m2025-11-04 03:28:21.192 DEBUG (MainThread) [zigpy.topology] Found unknown device nwk=0x0D70e[0m
e[36m2025-11-04 03:28:22.416 DEBUG (MainThread) [zigpy.topology] Found unknown device nwk=0x25C7e[0m
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
e[33m2025-11-04 05:25:51.541 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.543 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.545 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.546 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration presence_simulation which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.547 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.548 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bhyve which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-04 05:25:51.550 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[31m2025-11-04 05:26:03.634 ERROR (Thread-10) [pychromecast.socket_client] [Upstairs speaker(b409cbce-8361-a8d7-4fc4-dccad10a5fcd.local.):8009] Failed to connect to service MDNSServiceInfo(name='Google-Nest-Mini-b409cbce8361a8d74fc4dccad10a5fcd._googlecast._tcp.local.'), retrying in 5.0se[0m
e[36m2025-11-04 05:26:03.799 DEBUG (ImportExecutor_0) [zigpy.appdb] SQLite version for <module 'sqlite3' from '/usr/local/lib/python3.13/sqlite3/__init__.py'>: 3.49.2e[0m
e[32m2025-11-04 05:26:03.945 INFO (ImportExecutor_0) [zigpy.serial] Using pyserial-asyncio-fast in place of pyserial-asyncioe[0m
e[36m2025-11-04 05:26:05.352 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.adeo'e[0m
e[36m2025-11-04 05:26:05.355 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.adeo.color_controller'e[0m
e[36m2025-11-04 05:26:05.360 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.aduro'e[0m
e[36m2025-11-04 05:26:05.363 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.aduro.adurolightncc'e[0m
e[36m2025-11-04 05:26:05.383 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.aurora'e[0m
e[36m2025-11-04 05:26:05.386 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.aurora.aurora_dimmer'e[0m
e[36m2025-11-04 05:26:05.397 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bitron'e[0m
e[36m2025-11-04 05:26:05.405 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bitron.thermostat'e[0m
e[36m2025-11-04 05:26:05.428 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch'e[0m
e[36m2025-11-04 05:26:05.486 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch.isw_zdl1_wp11g'e[0m
e[36m2025-11-04 05:26:05.500 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch.motion'e[0m
e[36m2025-11-04 05:26:05.515 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch.rbsh_rth0_zb_eu'e[0m
e[36m2025-11-04 05:26:05.518 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch.rbsh_trv0_zb_eu'e[0m
e[36m2025-11-04 05:26:05.524 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.bosch.relay_rbsh-mms-zb-eu'e[0m
e[36m2025-11-04 05:26:05.554 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.candeo'e[0m
e[36m2025-11-04 05:26:05.737 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.candeo.sensors'e[0m
e[36m2025-11-04 05:26:05.786 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.candeo.wall_modules'e[0m
e[36m2025-11-04 05:26:05.854 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite'e[0m
e[36m2025-11-04 05:26:05.965 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3130'e[0m
e[36m2025-11-04 05:26:06.011 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3157100'e[0m
e[36m2025-11-04 05:26:06.013 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3300S'e[0m
e[36m2025-11-04 05:26:06.016 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3305S'e[0m
e[36m2025-11-04 05:26:06.023 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3310S'e[0m
e[36m2025-11-04 05:26:06.027 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3321S'e[0m
e[36m2025-11-04 05:26:06.032 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.cl_3460L'e[0m
e[36m2025-11-04 05:26:06.035 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.ias'e[0m
e[36m2025-11-04 05:26:06.038 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.motion'e[0m
e[36m2025-11-04 05:26:06.039 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.centralite.motionandtemp'e[0m
e[36m2025-11-04 05:26:06.043 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.const'e[0m
e[36m2025-11-04 05:26:06.044 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.custom'e[0m
e[36m2025-11-04 05:26:06.048 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.custom.telink'e[0m
e[36m2025-11-04 05:26:06.066 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.danfoss'e[0m
e[36m2025-11-04 05:26:06.067 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.danfoss.thermostat'e[0m
e[36m2025-11-04 05:26:06.068 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco'e[0m
e[36m2025-11-04 05:26:06.093 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.air_quality'e[0m
e[36m2025-11-04 05:26:06.096 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.emi'e[0m
e[36m2025-11-04 05:26:06.098 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.heat_alarm'e[0m
e[36m2025-11-04 05:26:06.099 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.humidity'e[0m
e[36m2025-11-04 05:26:06.102 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.intelligent_keypad'e[0m
e[36m2025-11-04 05:26:06.105 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.io_module'e[0m
e[36m2025-11-04 05:26:06.108 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.motion'e[0m
e[36m2025-11-04 05:26:06.110 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.open_close'e[0m
e[36m2025-11-04 05:26:06.114 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.power_plug'e[0m
e[36m2025-11-04 05:26:06.120 DEBUG (SyncWorker_2) [zhaquirks] Loading quirks module 'zhaquirks.develco.smart_button'e[0m
Any help is appreciated!
