Hi guys,
I have followed the raspberryPi guide and I have installed hass on my armbian system.
Homeassistant runs using systemctl service without any problem but I cannot see any log file inside the .homeassistant folder
I already check access permission on folder and seems fine. Below the result.
pi@homedaemon:/home/homeassistant/.homeassistant$ ls -l
total 120388
-rw-r--r-- 1 homeassistant homeassistant 1370 Mar 15 06:33 automations.yaml
-rw-r--r-- 1 homeassistant root 244 Mar 15 06:33 binary_sensor.yaml
-rw-r--r-- 1 homeassistant homeassistant 7568 Mar 29 19:33 configuration.yaml
-rwxr-xr-x 1 homeassistant root 191106 Mar 19 12:11 configurator.py
drwxr-xr-x 3 homeassistant root 4096 Mar 15 21:22 custom_components
-rw-r--r-- 1 homeassistant homeassistant 2762 Mar 17 19:33 customize.yaml
drwxr-xr-x 2 homeassistant homeassistant 4096 Mar 15 21:10 deps
-rw-r--r-- 1 homeassistant homeassistant 2852 Mar 29 19:42 groups.yaml
-rw-r--r-- 1 homeassistant homeassistant 123015168 Mar 29 19:45 home-assistant_v2.db
-rw-r--r-- 1 homeassistant root 95 Mar 20 02:29 panels.yaml
drwxr-xr-x 2 homeassistant root 4096 Mar 15 21:22 scripts
-rw-r--r-- 1 homeassistant homeassistant 3 Mar 15 06:33 scripts.yaml
-rw-r--r-- 1 homeassistant homeassistant 696 Mar 16 19:35 secrets.yaml
-rw-r--r-- 1 homeassistant root 3144 Mar 29 19:42 sensors.yaml
-rw-r--r-- 1 homeassistant root 366 Mar 20 01:41 settings.conf
-rw-r--r-- 1 homeassistant root 172 Mar 15 06:33 switches.yaml
drwxr-xr-x 2 homeassistant homeassistant 4096 Mar 15 21:13 tts
pi@homedaemon:/home/homeassistant$ ls -a -l
total 44
drwxr-xr-x 7 homeassistant homeassistant 4096 Mar 28 19:48 .
drwxr-xr-x 4 root root 4096 Mar 15 21:07 ..
-rw------- 1 homeassistant homeassistant 758 Mar 28 19:48 .bash_history
-rw-r--r-- 1 homeassistant homeassistant 220 May 15 2017 .bash_logout
-rw-r--r-- 1 homeassistant homeassistant 3526 May 15 2017 .bashrc
drwx------ 3 homeassistant homeassistant 4096 Mar 15 21:08 .cache
drwxr-xr-x 7 homeassistant homeassistant 4096 Mar 29 19:48 .homeassistant
drwx------ 10 homeassistant homeassistant 4096 Mar 16 14:39 Maildir
drwxr-xr-x 2 homeassistant homeassistant 4096 Mar 28 19:48 .nano
-rw-r--r-- 1 homeassistant homeassistant 675 May 15 2017 .profile
drwx------ 2 homeassistant homeassistant 4096 Mar 16 11:25 .ssh
Do you have any hint to find out whatâs going wrong?
I think the default user is âpiâ who canât modify the files, so many of the docs out there say to âsudoâ to ârootâ to do this or that. Before moving to hass.io I would modify files and change the owner/group to homeassistant.
Maybe because your default log level is Critical and you donât have any critical entry to log⌠Try changing the log level to Info, reboot and see if the log file appears.
