Hello I set this up around a month ago with a couple of devices and it works really well but now I would like to add more devices but can not see how to add a device .
Could someone please advise how to achieve this.
Best Regards Chris
Use the HA app:
- Go to Devices and Services
- Click on the Matter Integration
- Click Add Device
@paulbates …wrong integration, this is the HA Matter-Hub…
To add a device to an existing bridge depends on how you set it up, I just use lables attached to entities I want to share with the matter hub, open the UI and look at your bridge, then look at the ’ Entity Filters’ section…
