Been using node red for months without issue then suddenly the home assistant palette is missing and all the home assistant nodes show as UNKNOWN. All the existing flows work fine and weirdly if I load up node red on my phone the palette shows and everything is as expected.
Anyone had this issue before or know how I can fix it?
Thanks, trying another machine worked but clearing the browser cache didn’t, does node red cache elsewhere that isn’t covered by clearing the browser cache?
You can try disabling cache for the page. Btw if you aren’t using the direct access you should, your HA ip with 1880 instead of 8123. If that is what you are using go to the nodered page. Open the debug console on the browser (f12) → network tab → check disable cache and refresh. (FF and chrome)
