Home Assistant not reachable after new modem
Hi there,
Because i had some problems with my modem, i got a new one installed. Strangely, now i cannot reach Home Assistant anymore. Also when i login to the new modem, i can’t find HA so i also don’t know if HA has got a new IP-adress. Does anyone have any idea what could cause this problem and how to solve it?
Thanks in advance!
I found out that HA isn’t detected by my modem as the port the HA is plugged in is set empty in the admin panel of the router… Any suggestions.
I fixed it by updating the network settings with the following command:
network update eth0 --ipv4-method auto --ipv6-method disabled
