hello when I try to update from 0.107.7 to 0.108 it gives me the following error:
log:
20-04-09 06:03:27 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.0
20-04-09 06:03:27 INFO (SyncWorker_2) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.107.7 to homeassistant/qemux86-64-homeassistant:0.108.0
20-04-09 06:03:27 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.0.
20-04-09 06:03:42 ERROR (SyncWorker_2) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.108.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
20-04-09 06:03:42 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Having the same issue upgrading from 107.7 to 108.2
20-04-10 14:26:09 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.2
20-04-10 14:26:09 INFO (SyncWorker_0) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.107.7 to homeassistant/qemux86-64-homeassistant:0.108.2
20-04-10 14:26:09 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.2.
20-04-10 14:26:09 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.108.2 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:46036->[::1]:53: read: connection refused").
20-04-10 14:26:09 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
I do not have adguard or pihole installed on my system or network currently. docker.io forwards me to docker.com as expected and following https://registry-1.docker.io/v2/ through the browser also results in an unauthorized access json response.
So I’m not leaning towards a dns issue, but its been a long quarantine so far and I’m missing the small details on things these days ha
Similar issue with me trying to upgrade from 107.7 to 108.2:
20-04-10 16:01:22 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.2
20-04-10 16:01:22 INFO (SyncWorker_1) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.107.7 to homeassistant/qemux86-64-homeassistant:0.108.2
20-04-10 16:01:22 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.2.
20-04-10 16:02:41 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.108.2 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.108.2: No such image: homeassistant/qemux86-64-homeassistant:0.108.2").
20-04-10 16:02:41 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Me too. Same Issue from 0.107.7 to 0.108.3. The strange thing is that the Updater indicate to update to 0.108.2 and Supervisor to 0.108.3 but nothing works.
That’s my log:
20-04-11 09:33:13 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.108.3 → 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.108.3: No such image: homeassistant/qemux86-64-homeassistant:0.108.3”).
20-04-11 09:33:13 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
20-04-11 09:33:13 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock..wrap_api() done, defined at /usr/src/supervisor/supervisor/utils/init.py:22> exception=HomeAssistantUpdateError()>
I’ve rebooted, checked disk space, DNS, etc… I’m on the latest OS, etc… no changes and it has been updating fine until now. I get the log below.
20-04-20 16:32:56 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.6
20-04-20 16:32:56 INFO (SyncWorker_3) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.107.7 to homeassistant/qemux86-64-homeassistant:0.108.6
20-04-20 16:32:56 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.6.
20-04-20 16:33:28 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.108.6 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.108.6: No such image: homeassistant/qemux86-64-homeassistant:0.108.6").
20-04-20 16:33:28 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
@francisp I appreciate the assistance. I’m not having any luck with getting SSH to the system though. I’ve created my key pair, added the authorized_keys file to my usb and ran the import. nothing seems to happen, and I still can’t ssh into the box. I will keep trying.
Ok, I got it. And upon further inspection I was out of disk space like you had originally said several posts above. I expanded my storage and it updated fine. All is well. Thanks @francisp!
