Home Assistant on RPI5, 14.2, using SD card SanDisk Extreme A2, 128gb
Hello
I have a problem install HA OS on SDXC SanDisk, After Installation make me a lot of small partition .
I tried to flash the card ussing Balena Etcher with iso, the same problem . Other verison of Home Assistant installed perfectly.
I haven’t microHDMI cable to see what happend there if installed .
I got another SD card of 64 GB but not tried yet .
Can you help me with this?
Hello all
I discovered that problem was from divice SD card reader from the laptop. I buy an usb card reader and flash the SD card without problems.
Everything is working ok now.
