Home assistant PE edition: impossible to unmute?
when i got it. i set it up and it ran for 2 days. when i came in yesterday and wanted to work with home assistant. it was there with the 2 red lights. i haven’t done anything. it was just like that
How much amps does the power unit provide and is it a good one?
Maybe try another one.
I have tried it directly on the computer. I don’t know how many amps from there. But a power supply with 500 mA and another with 1 amp. both are good power supplies.
I have noticed that the left red diode flashes once in a while. but not evenly.
Aparrantly you have not read the troubleshooting (well)…
no, I hadn’t seen that :frowning:
I just tried a power supply that gives 2 - 3.5 amps
But it’s still the same
Just an idea, with this power supply though:
Then I tried it again with that power supply.
it didn’t help. still the same
Did this coincidentally happen after using the mute switch?
I’ve never used the mute switch. Only after it happened. I was hoping it had just settled down a bit so it had turned off.
Well, I’m out of ideas.
Thank you for trying. I’m sending it back.
Same issue. It hapans from begining after first conection/instalation. But can use it like media player. Did you fix issue?
Fixed by off physical swith on Voice PE box ). It seems like a power swith but it’s mute swith.
