Here’s what I see in my log:
Logger: aiohue.v2[192.168.0.115].events
Source: runner.py:128
First occurred: February 22, 2023 at 4:32:36 PM (40 occurrences)
Last logged: 11:39:07 AM
20 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
30 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
40 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
50 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
60 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
From the exported log:
2023-03-01 05:42:48.829 WARNING (MainThread) [aiohue.v2[192.168.0.115].events] 10 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
2023-03-01 05:56:32.894 WARNING (MainThread) [aiohue.v2[192.168.0.115].events] 10 Attempts to (re)connect to bridge failed - This might be an indication of connection issues.
2023-03-01 06:05:24.540 ERROR (MainThread) [wyzeapy.services.update_manager] Unknow error happened during updating device info
File “/usr/local/lib/python3.10/site-packages/aiohttp/connector.py”, line 1154, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File “/usr/local/lib/python3.10/site-packages/aiohttp/connector.py”, line 880, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File “/usr/local/lib/python3.10/site-packages/aiohttp/resolver.py”, line 33, in resolve
infos = await self._loop.getaddrinfo(
File “/usr/local/lib/python3.10/asyncio/base_events.py”, line 860, in getaddrinfo
return await self.run_in_executor(
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/usr/local/lib/python3.10/socket.py”, line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/local/lib/python3.10/site-packages/wyzeapy/services/update_manager.py”, line 40, in update
self.device = await self.service.update(self.device)
File “/usr/local/lib/python3.10/site-packages/wyzeapy/services/bulb_service.py”, line 71, in update
device_info = await self._get_property_list(bulb)
File “/usr/local/lib/python3.10/site-packages/wyzeapy/services/base_service.py”, line 164, in _get_property_list
response_json = await self._auth_lib.post(“https://api.wyzecam.com/app/v2/device/get_property_list”,
File “/usr/local/lib/python3.10/site-packages/wyzeapy/wyze_auth_lib.py”, line 219, in post
response = await _session.post(url, json=json, headers=headers, data=data)
File “/usr/local/lib/python3.10/site-packages/aiohttp/client.py”, line 535, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.10/site-packages/aiohttp/connector.py”, line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.10/site-packages/aiohttp/connector.py”, line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.10/site-packages/aiohttp/connector.py”, line 1166, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.wyzecam.com:443 ssl:default [Try again]
…repeated several hundred times.
I don’t see anything in my VM logs. There’s literally nothing between me starting up the VM and, several days later, remote desktoping to that PC.
