Since the update of march every couple of days my home assistant won’t start.
I get this popup:
When i unplug my raspberry pi and plug it back in it will load up as normal.
I have restart my modem + router, but it seems not to help.
I haven’t installed anything else like addons or so.
I don’t know what to do.
Also i tried locally to start home assistant and this is also not loading, so it’s not app related.
tom_l
2
Don’t do that. It is a guaranteed way to corrupt your SD card.
Next time you cant connect plug a monitor and keyboard in to the pi to see what is going on. You can check the ip address and view the logs.
I use external SSD, is it the same?
tom_l
4
It certainly won’t be good for it, or your recorder database integrity.
WallyR
(Wally)
5
Check that the addresses for internal and external are correct under network in HA.
I use home assistant cloud
Today i noticed this:
Nabu Casa says i’m not connected remotely
While in home assistant itself it is telling me i’m logged in and connected:
I tried te disable home assistant cloud and enable it again, but now i get an ssl handshake error (i’m not at home right now)
Logged out from home assistant cloud within home assistant, logged back in and now everything is working correctly.
