Hi guys,
i just set up a new fritzbox and i now work with DHCP and IP-reservation instead of fix ip addresses.
I did this to not have to edit very hostname manually.
Every device is promoting their correct hostname, except home assistant. It’s shown as 027A9B01F2DF0000.
I could change it manually but i want to know what the problem is.
Under System → Network → Hostname i set it to “haos” but he does not promote this hostname…
Maybe anyone has a solution for this.
Thank you very much!
