I wonder if anyone could help me troubleshoot a problem I have with HA.
I have HA installed bare metal on a ZOTAC ZBOX CI320NANO-PLUS pc. Its been running fine for over a year but lately it randomly goes offline. I can't access it via the LAN or from the companion app on my phone. If I ping the IP address I do not get a reply. Either the system has locked up or crashed. The only way I can bring it back online is to hard re-start the pc.
I regularly install Core and OS updates but it doesn’t seem to relate to a particular update. The only other issue I have found is that on occasions Z2M is not running and I have to start it manually even though watchdog is ticked. I also had some errors related to Tuya Local but I have disabled the devices which were causing the errors
Its in an awkward location to attach a monitor when a crash happens so I am hoping I can see something from the logs to point me in the right direction. I have looked through the logs but to be honest do not know where to start and which logs to inspect. That said, if the system is locking up then perhaps the logs aren’t being written for the fault?
The only other thought was that the NUC was second hand and I wonder if the internal SSD might have errors. There are some complicated workarounds I've found online but no direct way to check the disk from within HASOS.
I might have another machine I could use and automatic backups are still working when its running but I am concerned if I did a clean restore of HA if then reinstalling from a backup might re-corrupt the OS
If anyone could point me at some troubleshooting tips I would appreciate it
