Since this morning my Home Assistant reboots. The Nuc where the HA installation is hosted does not reboot it only looks like it is Home Assistant
- Installation: Home Assistant OS
- Core: 2025.6.3
- Supervisor: 2025.06.2
- Operating System: 15.2
- Frontend: 20250531.4
I did a reboot into safe mode but here HA also restarts. Looking at the CPU temperate it looks like every time: 45 to max 60 degree.
Looking at the home assistant log.1 I found this here:
2025-06-29 16:02:34.599 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.600 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.600 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xplora_watch which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.601 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.601 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration gardena_smart_system which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.602 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ms365_mail which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.602 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration flightradar24 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.603 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ingress which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.603 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ms365_calendar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.604 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration homematicip_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.604 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ui_lovelace_minimalist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.605 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.605 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration iphonedetect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.606 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dwd_pollenflug which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.606 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration unifi_voucher which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.607 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration material_symbols which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.607 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ms365_todo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.608 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.608 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration isitpayday which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.608 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration area_occupancy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.609 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration llmvision which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.610 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dwd_weather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.610 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ms365_teams which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.610 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bing_wallpaper which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:34.611 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-29 16:02:36.166 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-06-29 16:02:36.198 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=1646 from 2025-06-29 14:00:17.723570)
2025-06-29 16:02:39.811 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/__init__.py:2: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
__import__('pkg_resources').declare_namespace(__name__)
2025-06-29 16:02:41.909 WARNING (MainThread) [homeassistant.helpers.frame] Detected that integration 'deconz' calls `device_registry.async_get_or_create` referencing a non existing `via_device` ('mac', '7e:8a:0b:44:fd:1d'), with device info: {'configuration_url': 'homeassistant://hassio/ingress/core_deconz', 'entry_type': <DeviceEntryType.SERVICE: 'service'>, 'identifiers': {('deconz', '00212E06E1C8')}, 'manufacturer': 'Dresden Elektronik', 'model': 'deCONZ', 'name': 'Phoscon-GW', 'sw_version': '2.30.2', 'via_device': ('mac', '7e:8a:0b:44:fd:1d')} at homeassistant/components/deconz/hub/hub.py, line 187: device_registry.async_get_or_create(. This will stop working in Home Assistant 2025.12.0, please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+deconz%22
2025-06-29 16:02:45.019 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/ProtocolMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.020 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/AudioFadeMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.021 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/PlayerPath.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.022 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/Origin.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.022 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/DeviceInfoMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.023 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/Common.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.024 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/NowPlayingClient.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.025 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/NowPlayingPlayer.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.025 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/AudioFadeResponseMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.026 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/ClientUpdatesConfigMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.027 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/ConfigureConnectionMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.027 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/CryptoPairingMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.028 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/GenericMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.028 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/GetKeyboardSessionMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.029 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/GetRemoteTextInputSessionMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.030 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/GetVolumeMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.030 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/GetVolumeResultMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.031 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/KeyboardMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.032 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/ModifyOutputContextRequestMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.032 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/google/protobuf/runtime_version.py:98: UserWarning: Protobuf gencode version 5.28.1 is exactly one major version older than the runtime version 6.31.1 at pyatv/protocols/mrp/protobuf/NotificationMessage.proto. Please update the gencode to avoid compatibility violations in the next runtime release.
warnings.warn(
2025-06-29 16:02:45.858 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'webrtc' accessed lovelace_data['resources'] instead of lovelace_data.resources at custom_components/webrtc/utils.py, line 129: resources: ResourceStorageCollection = hass.data["lovelace"]["resources"]. This will stop working in Home Assistant 2026.2, please create a bug report at https://github.com/AlexxIT/WebRTC/issues
2025-06-29 16:02:46.535 WARNING (MainThread) [homeassistant.components.samsungtv] Failed to get mac for 10.1.50.100
2025-06-29 16:02:48.096 WARNING (MainThread) [custom_components.area_occupancy.virtual_sensor.wasp_in_box] No door or motion entities configured for Wasp in Box sensor. Sensor will not function properly.
2025-06-29 16:02:51.009 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.office_download_andre (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total' which is impossible considering device class ('data_rate') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-06-29 16:02:51.011 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.kuhlschrank_keller_energieverbrauch (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('power') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-06-29 16:02:56.636 WARNING (MainThread) [homeassistant.components.thread.dataset_store] Got dataset with same extended PAN ID and same or older active timestamp, old dataset: '0e080000000000000000000300001935060004001fffc00208ed1bf180bee24b120708fded1bf180be00000510d3a4aca04e92215e8bcbba3e9ec4b65e03084d79486f6d653239010291d3041081f70d1e914c1c032188a50866a9b8c00c0402a0f7f8', new dataset: '4a0300000f0e080000000000000000000300001935060004001fffc00208ed1bf180bee24b120708fded1bf180be00000510d3a4aca04e92215e8bcbba3e9ec4b65e03084d79486f6d653239010291d3041081f70d1e914c1c032188a50866a9b8c00c0402a0f7f8'
2025-06-29 16:03:02.195 WARNING (MainThread) [custom_components.hacs] You have 'Kibibit/hass-kibibit-theme' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Not maintained anymore)
2025-06-29 16:03:10.934 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.wall_display_esszimmer_wartungsmodus are missing or not currently available
2025-06-29 16:03:11.428 WARNING (MainThread) [homeassistant.components.thread.dataset_store] Got dataset with same extended PAN ID and same or older active timestamp, old dataset: '0e080000000000000000000300001935060004001fffc00208ed1bf180bee24b120708fded1bf180be00000510d3a4aca04e92215e8bcbba3e9ec4b65e03084d79486f6d653239010291d3041081f70d1e914c1c032188a50866a9b8c00c0402a0f7f8', new dataset: '4a0300000f0e080000000000000000000300001935060004001fffc00208ed1bf180bee24b120708fded1bf180be00000510d3a4aca04e92215e8bcbba3e9ec4b65e03084d79486f6d653239010291d3041081f70d1e914c1c032188a50866a9b8c00c0402a0f7f8'
2025-06-29 16:03:11.746 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.13/site-packages/miio/miot_device.py:23: FutureWarning: functools.partial will be a method descriptor in future Python versions; wrap it in enum.member() if you want to preserve the old behavior
Bool = partial(_str2bool)
2025-06-29 16:03:12.816 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.bubble_card_modules exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-06-29 16:03:12.904 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.bubble_card_modules exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-06-29 16:03:29.075 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140631363275488] Error handling message: Unknown error (unknown_error) André Rink from 10.1.40.65 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.4 Safari/605.1.15)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 28, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 544, in handle_manifest_list
raise int_or_exc
homeassistant.loader.IntegrationNotFound: Integration 'bermuda' not found.
2025-06-29 16:03:42.324 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140631363275488] Error handling message: Unknown error (unknown_error) André Rink from 10.1.40.65 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.4 Safari/605.1.15)
raise int_or_exc
2025-06-29 16:04:06.026 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140631363275488] Error handling message: Unknown error (unknown_error) André Rink from 10.1.40.65 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.4 Safari/605.1.15)
raise int_or_exc
2025-06-29 16:04:10.114 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140631363275488] Error handling message: Unknown error (unknown_error) André Rink from 10.1.40.65 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.4 Safari/605.1.15)
raise int_or_exc
