Home Assistant Security (especially when using add-ons)
I have been checking the strength of all the passwords for HA users because I am preparing to open a port for my HA.
However, I use the Mosquitto add-on and I can’t use 2FA for the HA user that I have created specifically for access to the MQTT broker. Is there a way around this because if not it seems like a bit of a security issue.
Not in of itself it isn’t, but having one user without 2FA does seem to diminish the point of using 2FA for any users.
Or am I wrong?
Or is there a way around this?
I don’t think that should be an issue unless you want to open the MQTT broker to the internet. A potential hacker would first need access to your network before he can access the MQTT broker and if he already has access to the network it’s anyway too late.
If he’s using a home assistant user for mqtt that can also be used to log in to home assistant.
Personally I think it’s a small target in a big pond and just use a very strong password.
Interested to hear alternatives though.
Ok, didn’t know that, thanks for the info.
Yes, that was the point I was trying to make.
I guess you could use a local user defined in the mqtt addon config.
