Home Assistant Sky Connect Integration
hi,
I am user of HA SkyConnect for few Years I works very well I and didn’t had issues with it. I am using “Zigbee Home Automation” integration for it without and issues. After recent update of HA (amd64 image with tag stable) new integration ‘appeared’ in my HA called ’ Home Assistant Sky Connect’.
Integration ‘Home Assistant Sky Connect’ always fail to start (I assume that is because device is taken by Zigbee Home Automation). Is ’ Home Assistant Sky Connect’ intergation suppose to replace all other ones or can I somehow make both ’ Home Assistant Sky Connect’ and ‘Zigbee’ work together in the same time ?
