Home assistant stopped working - weird extra partitions
Up unit a few days ago HA worked fine. A few days ago I noticed the CPU temp rose from about 50-55deg. to about 69deg. The fan worked fine and so did HA, so I tried to find out what was wrong, tried to get the latest updates etc.
After a few days HA was unresponsive, could still ping the Pi, but that was it. Rebooting helped, but after a few hours the same.
Now the Pi is not pingable anymore.
Put the Pi on a monitor and keyboard. The Pi boots until a Home assistant login, after logging in as root I get the message that the CLI is not loaded and I end up with some emergency prompt.
This summer I installed HA on a 120 GB SSD (RPi 3B), which has worked fine until now. I connected the SSD to a Linux machine. The partitions seem to be accessible, but I seem to have more partitions as expected:
Kernel0 / System0 / Kernel1 / System1.
I’m at a loss here. Does someone know what’s wrong here and if it’s fixable or should I reinstall? Reinstalling is simple enough, but I need to what caused this or else I will be reinstalling again next week.
Edit 03-11: Seems the partitions have nothing to do with the problems, because they appear also with a fresh install. Did a fresh install and restored a backup and now everything seems ok again. For now.
Thanks in advance.
