Home Assistant stops being accessible
Hope someone can help me as my Home Assistant keeps going offline and not accessible. It seems to go offline very frequently…at least every hour. I am also starting to see long periods at night when the system is down and it comes back online around 6 or 7am.
I have two instances of home assistant running on my network both managing different sensors and one of them works perfectly.
I have looked through the logs and am seeing many “Home Assistant Core state change” and “Starting system autofix at state running” but I am at a loss whether these are issues or not.
In addition I am seeing error message
 " AttributeError: 'NoneType' object has no attribute 'close'
2025-01-21 10:33:39.043 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-23595' coro=<HomeAssistantWebSocket.async_supervisor_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:322> exception=AttributeError("'NoneType' object has no attribute 'close'")>
  File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 267, in async_send_message
    await self._client.async_send_command(message)
  File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 95, in async_send_command
    return await self._futures[message["id"]]
supervisor.exceptions.HomeAssistantWSConnectionError: Connection was closed
  File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 327, in async_supervisor_event
    await self.async_send_message(
  File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 269, in async_send_message
    await self._client.close()
2025-01-21 10:33:39.045 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed ('172.30.32.1', 8123)]"
This IP address is the HASSIO docker.
Home assistant core is 2025.1.2
Supervisor is 2024.12.3
I am floundering and would welcome some direction to resolve!!
I am seeing the exact same error. All of my addons and integrations crashed as well. So far only happened once and a reboot brought everything back.
  • Core 2025.1.3
  • Supervisor 2024.12.3
  • Operating System 14.1
  • Frontend 20250109.0
I am experiencing the exact same problem with the same error messages. Has anyone found a solution to this. I am having to manually restart HA once evry two days. when this happens all of my ICMP integrationsdisplay as offline.
