Home Assistant has really let itself go. Only a couple of years ago, you were able to run Home Assistant on a Raspberry Pi 3B with 1GB of RAM. Now it struggles with 2GB, and some users even recommend 4GB-8GB for comfort. To add insult to injury, the two most lightweight installation methods were recently retired. You are now forced to dedicate a whole computer to Home Assistant OS, create a virtual machine with RAM reserved for Home Assistant OS, or choose the Container method and sacrifice the ability to manage add-ons seamlessly. This is obviously a deplorable state of affairs in the post-AI economy.
It doesn’t have to be this way. I’m going to show you one weird trick to cut the fat, discovered by a stay-at-home mom cosplaying as a sysadmin, that Big Pharma doesn’t want you to know.
Here, I document the easy process to add a Home Assistant Supervised installation to an existing Linux server with Incus/LXC. The result is a near-HAOS experience, complete with add-on management UI, that shares resources with the rest of your homelab. This is ideal for testing instances. LXC does not offer as much isolation as full virtualization, of course, but I would hope you trust the software that controls your home. This installation method is also unsupported, unfortunately, and this is my vote to bring Supervised back.
Start with Incus on a Linux server. You could do this any way you want. This should work with vanilla LXC if you’re willing to do some extra work.
Create a Debian container. You’re going to want a privileged container that supports nested containers.
host# incus create images:debian/13 homeassistant -c security.privileged=true -c security.nesting=true
- Configure the network. You could forward port 8123 to the container or set up a bridge. If you had separate VLANs for your trusted devices and your smart devices, you could add the container to both. You could mix and match:
host# incus config device add homeassistant proxy-8123 proxy listen=tcp:0.0.0.0:8123 connect=tcp:127.0.0.1:8123
host# incus config device add homeassistant eth0 nic nictype=bridged parent=br0
host# incus config device add homeassistant eth1 nic nictype=bridged parent=br1
- Install Home Assistant (Supervised) in the container. During the installation process,
homeassistant-supervised.debis going to try and fail to set/proc/sys/kernel/dmesg_restrict. The “right” way is to patch that out of thepreinstscript. We’re going to take the quick and dirty way of protecting/proc/sys/kernelwith a tmpfs. We’ll also need a little script to start Home Assistant on boot.
host# incus start homeassistant
host# incus exec homeassistant bash
homeassistant# apt update && apt install -y lsb-release curl
homeassistant# source /etc/os-release
homeassistant# curl -fsSL https://download.docker.com/linux/${ID}/gpg -o /etc/apt/keyrings/docker.asc
homeassistant# echo "deb [signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/${ID} ${VERSION_CODENAME} stable" > /etc/apt/sources.list.d/docker.list
homeassistant# curl -LO https://github.com/home-assistant/supervised-installer/releases/download/4.0.1/homeassistant-supervised.deb
homeassistant# curl -LO https://github.com/home-assistant/os-agent/releases/download/1.8.1/os-agent_1.8.1_linux_x86_64.deb
homeassistant# mount -t tmpfs none /proc/sys/kernel
homeassistant# apt update && apt install -y ./homeassistant-supervised.deb ./os-agent_1.8.1_linux_x86_64.deb
homeassistant# umount /proc/sys/kernel
homeassistant# systemctl restart systemd-resolved
homeassistant# dpkg --configure -a
homeassistant# rm homeassistant-supervised.deb os-agent_1.8.1_linux_x86_64.deb
homeassistant# echo '#!/bin/sh' > /etc/rc.local
homeassistant# echo 'while ! /usr/bin/ha core start; do sleep 2; done' >> /etc/rc.local
homeassistant# echo '/usr/bin/ha network reload' >> /etc/rc.local
homeassistant# echo 'exit 0' >> /etc/rc.local
homeassistant# chmod +x /etc/rc.local
- Restart the container. Although the web UI appears to be up, there are some subtle issues that linger until restarting.
host# incus restart homeassistant
Bonus: Assign optional peripherals, such as Zigbee or Z-Wave dongles:
host# incus config device add homeassistant sonoff-zbdongle-e unix-char required=false source=/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2... path=/dev/ttyUSB0
host# incus config device add homeassistant zooz-zst39 unix-char required=false source=/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick... path=/dev/ttyACM0
Problem: /usr/bin/ha fails with “OCI runtime exec failed: exec failed: unable to start container process: error executing setns process: exit status 1”.
Try restarting the container.
Problem: Docker container hassio_supervisor fails with “ERROR (MainThread) [supervisor.host.logs] Unable to connect to systemd-journal-gatewayd”.
You might have encountered this issue. Try updating the host or applying this workaround in the guest:
homeassistant# sed -ri 's/^(User=)/#\1/' /lib/systemd/system/systemd-journal-gatewayd.service
homeassistant# sed -ri 's/^(DynamicUser=)/#\1/' /lib/systemd/system/systemd-journal-gatewayd.service
homeassistant# systemctl daemon-reload
homeassistant# systemctl restart systemd-journal-gatewayd
homeassistant# docker restart hassio_supervisor
Problem: Home Assistant does not start on boot.
Start it with
ha core start, or create the startup script as above.
Problem: Home Assistant is unable to install add-ons because “‘AddonManager.install’ blocked from execution, no host internet connection”. ha network info shows “host_internet: false”.
It was DNS. Restart it with
ha network reload, or create the startup script as above.
