Home Assistant tools reporting tools
Small quality of life tools for Home Assistant reporting
I have been writing some scripts on retrieving information from Home Assistant.
My HA environment has been growing considerably in the past few years, and I discovered that applying proper administration, such as labels, areas, and categories, is always an afterthought. And, don’t even mention physically labeling your sensors, switches, and other hardware.
When you also have a mix of equipment, using Matter, Zigbee, and RF, you get to a point that it gets complex. Without proper administration t’s challenging to find the relation between an HA error, your HA environment, and the physical reality.
Untangling, auditing and administrating everything needs insight first, and for me, the HA web interface is not always my first choice; I am more of an Excel guy.
I had a couple of issues I wanted to audit and resolve.
1. Pulling and comparing Home Assistant and InfluxDB entities.
I’m using an InfluxDB database to collect a crazy amount of data from entities. I wasn’t sure which entities were actually being reported to InfluxDB compared to the entities that live in the HA environment. On paper it looked fine; you can see in the configuration what data is being sent to InfluxDB. But does it actually arrive there, and is it stored properly?
That’s why I created 2 Python scripts, HA_entities_reporting.py and HA_influx_reporting.py, that pull entity data from InfluxDB and Home Assistant in a way that makes it possible to compare which entities are available on Home Assistant and which entities are reported in InfluxDB. This enables you to find discrepancies between those two and if it’s complying with what you expected from your configuration.
2. Obtaining Matter and Thread information.
I have a growing number of Matter over Thread devices. There’s a lot of information available, using the “Open Home Foundation Matter Server”, but finding the relation between the HA devices and the Matter/Thread environment is not always obvious.
That’s the reason I’ve created a Python script, HA_matter_reporting.py, that attempts to report all the Matter devices and show as much information as possible about each device, including Thread information.
3. Audit your labeling.
I started labeling all my devices to make it easier to select groups of devices. When I say labeling, I mean labels, categories, areas, and floors. Once you’ve done that, creating scripts and automations will be much easier, or select subsets of devices and entities. The HA_labels_reporting.py script can help you with that. It reports on entities and devices, using custom rules. It’s easier to find devices that are missing labels or have wrong labels.
There are more ways leading to Rome.
I am aware there are probably many other ways to retrieve the information, but I’ve taken this approach. In case other community members can use these scripts to their advantage, I decided to share them in a Github repository. You are welcome to use them; they are there to share!
Next?
Not much, I’m afraid, but I will be sharing a document on how to use the CSV output files and pull them into Excel in the best way. This is especially convenient in the case of comparing InfluxDB with Home Assistant. Excel enables you to dynamically go through the data and see discrepancies.
