Home assistant triggers Alexa routine
I would like home assistant to trigger Alexa routine everyday at 2 pm but only when no one is at home. Can you help me with that ?
There are a few ways to do that. Do you already have your Home Assistant and Alexa connected? If so, what integration are you using?
I dont have it yet.
OK, the easiest way to connect them is to setup an account with Nabu Casa/Home Assistant Cloud once you setup your account follow the instruction for setting up Alexa. Nabu Casa is free for the first month and $5/month after that, which helps support the Home Assistant developers.
A second option for triggering routines, using Text-to-Speech, playing music, and other functions without a subscription is to use the Alexa Media Player (AMP) custom integration. Unlike Nabu Casa, AMP only works one-way. It does not allow Alexa to control entities in HA.
I dont mind paying 5$
