Home assistant UI stops working almost every day
It’s been like this since day one. Suddenly I try to access the UI and the page never opens. SSH still works and a restart solves the issue but how do I troubleshoot and fix it? This is a rental property and I can’t be involved every day.
Ehhh, I have the same problem, not sure how to fix/troubleshoot it.
Have you check your DB file, is it big? I noticed when I delete it (mine is 1Gb per day, and reaches 4Gb, and restart HASSIO I am fine for a day or 2. Just now I put MaraDB as hassio addon and in recorder: configuration.
Will tell if that will solve my case
