Home Assistant UI unreachable
the HA instance from my dad stopped working 2 days ago and didn’t came back since then. The system itself seems working. It’s listed in the network and it’s pingable.
I tried different things like downgrading the HA core to 2022.6.7, rebuilding HA core, restarting different parts of the system as well as rebooting the whole host. Nothing worked and it seems like that this happens from time to time to HA instances but nobody ever explains how they fixed it.
The instance runs on a generic x86 mini computer with an SSD as storage. The ssd was already checked and is fine.
The logs says the following:
supervisor log
22-07-13 17:14:43 ERROR (MainThread) [supervisor.utils] Can't execute stop while a task in progress
22-07-13 17:14:44 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
core logs
2022-07-13 17:23:43 ERROR (MainThread) [aiohttp.server] Error handling request
Traceback (most recent call last) :
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
ValueError: bad marshal data (unknown type code)
BTW: is there any option to access the OS over ssh if there is no ssh addon installed? Currently i can only access the command line with a second screen and keyboard. The problem is, that i have to manually copy every command or result between my pc and the cli.
Best regards
twittor
