Hello, I hope someone can help me with this issue. Nut sure if this is the right forum part.
Today I upgraded my Home assistant core installation as I always do:
sudo -u homeassistant -H -s
source /srv/homeassistant/bin/activate
pip3 install --upgrade homeassistant
I had some problems at first installing:
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
hass-nabucasa 0.54.1 requires cryptography<37.0,>=2.8, but you have cryptography 37.0.4 which is incompatible.
But several attempts seems to fix this issue. Home assistant is running version 2022.9 now.
But my Alarmo integration, installed with haccs, is not available anymore. Log shows:
Logger: homeassistant.setup
Source: setup.py:192
First occurred: 17:04:40 (1 occurrences)
Last logged: 17:04:40
Setup failed for custom integration alarmo: Unable to import component: No module named 'paho'
I’m running Ubuntu server 22.04 and that’s why I installed:
sudo apt install python3-paho-mqtt
But this does not solve this: Unable to import component: No module named ‘paho’
What do I miss here? It must be something simple. But I do not see what.
Edit:
I just tried to rebuild Home assistant as:
sudo su
systemctl stop home-assistant@homeassistant
cd /srv
mv homeassistant homeassistant_old
mkdir homeassistant
chown homeassistant:homeassistant homeassistant
cd /srv/homeassistant
python3.10 -m venv .
source bin/activate
python3 -m pip install wheel
pip3 install homeassistant
systemctl start home-assistant@homeassistant
To make sure I have a clean install. It took a while to start after that.
But I still have a problem with the alarmo integration looking for paho module.
Anyone knows how to solve?
