Home Assistant very slow, all kinds of errors etc
Good afternoon,
Suddenly Home Assistant is starting to behave strange. It is really slow and I get all kinds of errors.
It starts with a notification:
Invalid config
The following integrations and platforms could not be set up:
hacs
Please check your config and logs.
The log shows:
Setup failed for hacs: Requirements for hacs not found: ['hacs_frontend==20210214110032'].
13:19:00 – setup.py (ERROR)
Unable to install package hacs_frontend==20210214110032: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bf9bb0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/hacs-frontend/ WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bf9988>: Failed to establish a new connection: [Errno -3] Try again')': /simple/hacs-frontend/ WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bf9610>: Failed to establish a new connection: [Errno -3] Try again')': /simple/hacs-frontend/ WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bf98f8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/hacs-frontend/ WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bf9b80>: Failed to establish a new connection: [Errno -3] Try again')': /simple/hacs-frontend/ WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bc1340>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.12/armv7/ WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74bc1460>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.12/armv7/ WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74c52fd0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.12/armv7/ WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74c525e0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.12/armv7/ WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x74c52df0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.12/armv7/ ERROR: Could not find a version that satisfies the requirement hacs_frontend==20210214110032 (from versions: none) ERROR: No matching distribution found for hacs_frontend==20210214110032
13:19:00 – util/package.py (ERROR)
I am still able to SSH into the Raspberry Pi, however it is really slow. However, I am not able to login with FTP anymore (showing an error that the host isn’t communicating anymore since 15 seconds).
What can I do? I am losttt and desperately wanting to have it running again…
(Temporally) disable HACS, fix config, then enable again.
Can you please help me with how to do this?
Sorry, no. Don‘t use HACS by myself.
Hmm, maybe anyone else that can help?
Have you tried simply clicking on the 3 dots of the HACS Integration, and then click DISABLE?
