Home Assistant Voice PE - 40mm Speaker Enclosure
I have to start by saying that I am not the creator of this project. That honor would belong to freeskier93 on Maker World. They have created an enclosure remix for the HA Voice PE that replaces the original speaker with a 40mm speaker. I just finished printing and assembling it, and it is much louder than the original. The sound is great! I tried to find a post on here for the device and was unable to do so, here’s a link to the model. Check it out!!!
https://makerworld.com/en/models/1128800#profileId-1128651
If you are on here freeskier93, thank you!
Do you know if it’s compatible with the original top plate (and therefore also the ring etc.) and the volume switch?
In other words: If you print it in a matching color, can you just print the bottom part and the speaker plate and reuse the rest from the default case?
I’m not sure about the top part of the case being compatible with the top part of the original case, but the ring and button are attached to the PCB, so you can print the entire case and reuse the existing button and ring. You just don’t detach them from the PCB as you transition into the new case.
